1) Lift up the vehicle.
2) Remove under cover.
3) Place a container under drain pipe.
4) Loosen and remove drain screw to drain engine coolant into container.
6) Drain coolant from reservoir tank.
7) Tighten radiator drain screw securely after draining coolant.
8) Slowly pour prepared coolant from radiator filler port to neck of filler, then pour into reservoir tank up to “FULL” level.
Coolant amount for preparation
- 2.0 L non-turbo and 2.5 L models
- MT model: Approx. 6.8 L
- AT model: Approx. 6.7 L
9) Securely install radiator cap.NOTE:
The SUBARU Genuine Coolant containing antifreeze and anti-rust agents is especially made for SUBARU engine, which has an aluminum crankcase.
Always use SUBARU Genuine Coolant, since other coolant may cause corrosion.
10) Run engine for more than five minutes at 2,000 to 3,000 rpm. (Run engine until radiator becomes hot in order to purge air trapped in cooling system.)
11) Stop engine and wait until coolant temperature lowers. Then open radiator cap to check coolant level and add coolant up to radiator filler neck. Next, add coolant into reservoir tank up to “FULL” level.
12) After adding coolant, securely install radiator and reservoir tank caps.
Moj Legacy 2.5 BE 1999, Automatic, Sedan
- Prispevki: 4469
Re: Bodoca Subarujka :)
Izsek iz tovarniškega servisnega priročnika:
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
Supeer, najlepsa hvala, uredim zdaj se to..
evo hladilnik sem zamenjala, prejsnji pa je izgledal takole:
http://www4.slikomat.com/13/0312/blc-148931.jpg
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
Evo se par slikic koncno, pojutrisnjem pa dobi lepe feltnice
http://www4.slikomat.com/13/0313/rrk-148942.jpg
http://www4.slikomat.com/13/0313/xg4-148942.jpg
http://www4.slikomat.com/13/0313/4q-148942.jpg
Zadnji okvircek tablice gre tudi adijo zdaj en dan
Pa dobite se ko bo opran
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
http://www4.slikomat.com/13/0418/jxc-201704.png
In se ena z japoncem od sestricne katerega tudi obozujem, plus totalno enaka barva
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
Če se spomnite mojih grdih zimskih platišč
No seveda do zadnjih dni nisem našla časa za njih ampak na koncu sem
Na prvi sliki najprej kakšne so bile, desno pa po brušenju - za vsako feltno sem rabila po 1 uro strojnega in ročnega brušenja
Najprej sem hotela da so čisto črne
a ker imam temen avto sem rekla raje malo drugače in sem samo notranji krog obarvala v črno:
Kar sem po tem zaščitila in ostalo pobarvala s srebrno
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
Končni rezultat feltne:
In še na avtu (dodam še kakšno sliko ko bo moj srček opran in na lepši lokaciji)
Zgleda bolje kot prej a kar je najbolj pomembno - je pripravljen na sneeeeg
Tole je pa hudo dobr izpadl!
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
Mene je zanimalo, da bi se takole poigral...ampak mene osebno ne prepriča...
Moderatorji: Naj ji nekdo temo prestavi pod legacy/levorg, pa uredi naslov in vse, ker tole dejansko spada tja.
Prestavljeno. Z naslov pa naj SubaruLove pove kakšen bi imela.
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
Re: Moj Legacy 2.5 BE 1999, Automatic, Sedan
A tko?
Pozabu si na:
- SubaruLove
- Prispevki: 592
- Kraj: Ljubljana
