- Nebijedu
- Prispevki: 1783
- Pridružen: 23. September 2006, 02:03
Odgovor
Avtor: flat4 » 04. Februar 2009, 08:31
NoFEAR napisal/-a:Če piskanje koga moti, si ga lahko tud izklopi:
20 click method:
1.Turn the key to On position, do not start it. (2 clicks forward)
2. Wait till the first set of chimes starts.
3 .Quickly take your drivers side seatbelt buckle and insert and remove into latch exactly 20 times within 30 seconds. Don't rush it, just make sure to fully insert the tab all the way into the latch each time. You should end with the seatbelt unbuckled.
4. After 20 times, turn key to off, and remove key, then try turning back on and starting vehicle. Hopefully this will work for you now.
Sometimes you don't get it on the first few tries.. i am not sure why. Maybe timing? But it will work.
The result is different in that it doesn't do anything dangerous like undermine the airbag system. it simply disables the chime.
Using this method, you should hang on to the directions. If you have to unplug your battery, you will have to re-do it as the seatbelt chime will be re-enabled.
Obstaja tud še ena varianta, ampak pri tisti je treba izklopit en konektor pod sedežem...
emm, se ni lažje preprosto pripet?
Subi, čestitke za avto!
Dobr zgleda!
- Prispevki: 7945
- Pridružen: 15. November 2005, 22:33
- Kraj: Kamnik
Odgovor
Avtor: subi92 » 04. Februar 2009, 10:30
flat4 napisal/-a:
Dobr zgleda!
Ja jest tud ne vidim v tem kakga večjega problema k to mi je prva stvar k padm v avto
gore
- Prispevki: 955
Odgovor
Avtor: gore » 04. Februar 2009, 10:53
Sam pa - čeprav precej dam na varnost - se kar pogosto kam premaknem brez pripenjanja. Predvsem pri nas po vas - pa še kakšne umazane roke, pa raje čim manj šlatam po pasu
Pa me piskanje prej moti kot ne ...
- NoizeMaker
- Prispevki: 4009
- Pridružen: 09. Maj 2006, 11:15
- Kraj: Venera
Odgovor
Avtor: niva13 » 04. Februar 2009, 11:51
jaz se pripnem tudi, ce samo preparkiram avto, avtomatizem
gore
- Prispevki: 955
Odgovor
Avtor: gore » 04. Februar 2009, 14:22
niva13 napisal/-a:jaz se pripnem tudi, ce samo preparkiram avto, avtomatizem
Ja - da ne bo pomote. Sem zagovornik vseh teh varnostnih pripomočkov. Tudi pripenjam se redno. Se pa zgodi, da se kdaj po vasi ne.
Eden od razlogov je tudi, da imamo tisti z več oblinami (in mišic
) in kakšno debelo bundo, nekaj več dela z zatikanjem tistega hudiča. :34532
mojvoj
- Prispevki: 28
- Pridružen: 05. Januar 2009, 12:29
- Kraj: Lj
Odgovor
Avtor: mojvoj » 04. Februar 2009, 20:37
vse lepo in prav, ampak tole foresterjevo dretje ob nepripetju je pa res čist zgrešeno....
se matraš po eni zasneženi "vlaki" z 1km/h in ti ta hudič para živce....
- Prispevki: 5513
- Pridružen: 07. Maj 2006, 23:40
- Kraj: Trbowle
Odgovor
Avtor: BackW00d » 04. Februar 2009, 21:15
ni to samo subaru
to je modna muha vseh novih avtov
citroen recimo, čezdalje bolj naglas najeda...in nakonc je toook glasen, da moraš konkretno radio pojačat če ga še hočeš slišat
gore
- Prispevki: 955
Odgovor
Avtor: gore » 05. Februar 2009, 05:27
mojvoj napisal/-a:vse lepo in prav, ampak tole foresterjevo dretje ob nepripetju je pa res čist zgrešeno....
Ravno sedaj zjutraj sem imel podoben hec. Tukaj so mi na parkirišču narili kup snega, pa sem se seveda odpel, da lahko pri odprtih vratih spremljam kaj počnem - seveda hočem parkirati tam, kjer normalni ne
Če bi mi hudič ob pol petih zjutraj piskal, bi znorel (oz. odklopil
vrecha
- Prispevki: 1443
- Pridružen: 09. Januar 2008, 22:48
- Kraj: Ausard, WS
Odgovor
Avtor: vrecha » 05. Februar 2009, 07:12
Kolega ima na Outbacku za primere, ko ne želi biti privezan, še eno zaklopko od pasa v predalu. Jo zapne in je mir.
pilgrim
- Prispevki: 260
- Pridružen: 28. April 2006, 07:33
- Kraj: mb
Odgovor
Avtor: pilgrim » 05. Februar 2009, 18:23
gore napisal/-a: Če bi mi hudič ob pol petih zjutraj piskal, bi znorel (oz. odklopil
tuliti začne pri vožnji nad 20 km/h.
- Prispevki: 1132
- Pridružen: 22. Maj 2006, 17:47
Odgovor
Avtor: Unikat » 05. Februar 2009, 18:53
Mogoče je samoumevno in to že veste, ampak ta stvar čez čas neha piskat. Se mi zdi da čez kakšno minuto, če ne že prej.
gore
- Prispevki: 955
Odgovor
Avtor: gore » 05. Februar 2009, 19:00
pilgrim napisal/-a:gore napisal/-a: Če bi mi hudič ob pol petih zjutraj piskal, bi znorel (oz. odklopil
Če to drži, potem bi to kdaj pomagalo.
mojvoj
- Prispevki: 28
- Kraj: Lj
Odgovor
Avtor: mojvoj » 05. Februar 2009, 21:14
tuliti začne tudi če stojiš na mestu in eno izmed koles preseže 20km/h....kar se izredno hitro zgodi....
BMW_rok
- Prispevki: 838
- Pridružen: 10. April 2007, 10:53
- Kraj: Kamnik
Odgovor
Avtor: BMW_rok » 22. April 2009, 16:49
Uf super izgleda
