WRC Rallye de France - Tour de Corse
CrazyDriver
Prispevki: 288
Kraj: Rovte
Odgovor Avtor: CrazyDriver » 10. Oktober 2008, 19:42
Konec prvega dneva rallya po Korzki:
1. Loeb - Citroen (gee, what a surprise :D)
2. Hirvonen - Ford + 32s
3. Duval - Ford + 34s
4. Solberg - Subaru + 1min 11s
5. Latvala - Ford + 1min 12s
6. Atkinson - Subaru + 1min 15s
7. Gardemeister - Suzuki + 3min 16s
8. Mikkelsen - Ford + 3min 18s
9. Tirabassi - Subaru + 3min 21s
Sordo je v SS3 neki zaJ, trenutno na 54. mestu.
Drugače se pa naši odlično držijo :-)
Impreza WRC2008 No.5
Petter Solberg: “Four kilometres into stage three I had a huge moment braking into a right hander. Absolutely unbelievable! I think there’s some blue paint on the rock face there. The time was ok, but it’s tough. I have a big moment like that because I’m not taking it easy. I’m trying, you know. The first stage this morning was like Spain and we lost some time there, but the second two more abrasive so the grip was better.”
Impreza WRC2008 No.6
Chris Atkinson: “Ok, after this morning we’re close to Petter and Jari – the gap’s just over two seconds. I backed off a little to look after the tyres as they move around a lot on this surface, and that’s where I lost the time. We’re in a better position than in Spain though so it's a better start.”
Impreza WRC2008 No.14
Brice Tirabassi: “It’s not been an easy morning here but ninth position is good. The feeling here is different to Spain because the stages are very different – they’re slower and more twisty. Eighteenth on the road is no good for times though – there is gravel all over the road by the time we get to the stages so it’s hard. We’ll try some changes after service, but I’m quite happy so far.”
http://www.swrt.com/img_gallery/693472792.jpg
http://www.swrt.com/img_gallery/608640992.jpg
http://www.swrt.com/img_gallery/786429357.jpg
CrazyDriver
Prispevki: 288
Kraj: Rovte
Odgovor Avtor: CrazyDriver » 11. Oktober 2008, 22:57
Po drugem dnevu in odpeljanih 12 hp se je stanje rahlo spremenilo:
1. Loeb - Citroen
2. Hirvonen - Ford + 52s
3. Duval - Ford + 56s
4. Latvala - Ford + 1min 50s
5. Solberg - Subaru + 2min 13s
6. Atkinson - Subaru + 4min 6s
7. Aava - Citroen + 5min 49s
8. Tirabassi - Subaru + 7min 4s
Na SS9 je Atkinsonu počila guma, izgubil je minuto in pol.
Driver quotes from service D (after SS9)
Petter Solberg: “We tried something different with the car and we thought it should have been a little bit better. It was in some areas, but it was worse in the area we were working on so we lost time and a position to Jari. I’m quite confident that we know the reason why, so we now go back a little bit the other way and we’ll take Jari this afternoon. When we’re working on changing things, sometimes we go forwards and sometimes backwards, that’s just how it is.”
Chris Atkinson: “We’ve been pushing quite hard and were pretty close to Jari-Matti and Petter but then caught a rock in a cut on stage eight and got a puncture. We lost a minute and ten so now we’re out of the race now. The idea is to get the points for sixth as there’s a big gap behind us and now a big gap in front of us and we’re not going to catch them. See if anyone else who’s pushing has a problem.”
Brice Tirabassi: “It’s been a difficult morning as we’re starting ninth on the road so the roads are still dirty and there’s lots of gravel so grip is tricky. The stages have been very slippery so we haven’t been able to make up any places. It’s difficult on the tyres also because of the temperature.”
http://www.swrt.com/img_gallery/552867314.jpg
http://www.swrt.com/img_gallery/558312829.jpg
CrazyDriver
Prispevki: 288
Kraj: Rovte
Odgovor Avtor: CrazyDriver » 12. Oktober 2008, 21:27
Rally po Korziki je končan.
1. Loeb - Citroen
2. Hirvonen - Ford + 3min 24s
3. Duval - Ford + 3min 31s
4. Latvala - Ford + 3min 37s
5. Solberg - Subaru + 5min 35s
6. Atkinson - Subaru + 6min 10s
Tretji voznik, Tirabassi, je na drugi preizkušnji zadnjega dne odstopil zaradi tehničnih težav.
Dva rallya pred koncem je stanje po točkah sledeče:
Vozniki:
1. Loeb - Citroen 106
2. Hirvonen - Ford 92
3. Sordo - Citroen 59
4. Atkinson - Subaru 45
5. Latvala - Ford 42
6. Solberg - Subaru 40
Moštva:
1. Citroen 169
2. Ford 146
3. Subaru 87
4. Stobart Ford 62
Izgleda da bo letos vse pobral Citroen, kajti Hirvonen bo težko nadoknadil 14 točk na zadnjih rallyih, Ford je pa tudi malo preveč zadaj.
“We had a puncture on the final stage of the morning ten kilometres from the end of the stage, and then again in the final stage, so it’s disappointing but that’s what can happen” said Petter Solberg. “I think the first was a slow puncture as both times I didn’t hit anything. After that I drove smart, just taking it easy to get to the finish. I knew we didn’t have time to stop and change the wheel, and that it would be quicker to just drive to the finish of both stages.
“We’ve tried so many things with the car on this rally with different setups, and we have improved areas. That’s the problem of not having done any testing though – we make these changes on a rally. Some changes made the car better, some worse, but that’s how it goes. I’m happy with my performance on this rally though. We had a couple of punctures, but nobody could say I didn’t try! Now we look to Japan and going back to gravel on all new routes. I’ve never seen the stages before but I look forward to them.”
“We had a good start and we were fighting with Jari-Matti and Petter but then we had a puncture which lost us time” said Chris Atkinson. “Once we had the puncture and I was down I just took it quite safe and easy. In the end I could have pushed for the last day and a half and I might have beaten Petter after his two punctures, but you can never know that and we might have got a puncture anyway so that’s life.
“It’s been a good weekend though as we were on Petter’s pace before the puncture yesterday. I’ve driven a good rally and it’s good to get some points. I think Petter and I are pretty close on tarmac at the moment. He’s got an extra point or two out of these last two rallies but we’ve had a little bit of bad luck. I think we’re both pushing quite hard and that’s good for my driving still.”
“The car was much better this morning but for me it’s been hard to get a proper feeling this weekend” said Brice Tirabassi. “We made some changes last night and it was possible to speed up on the stages this morning. I was much happier.
“Then on the second stage after 9km we got a warning alarm in the car and after a few seconds the engine just stopped. It was not possible to restart the car. For sure it’s very disappointing, but for me it’s been a very good experience in Spain and Corsica and I am very happy. I enjoyed it a lot.
“Yes it’s been difficult, but it’s a rally so this can happen. I have a big smile and I am very happy with the team ad the car. It’s been very good experience and to drive a Subaru on these two rounds, especially on my home event, has been very good for me.”
http://www.swrt.com/img_gallery/187224565.jpg
http://www.swrt.com/img_gallery/275249054.jpg
http://www.swrt.com/img_gallery/318091119.jpg
P.S.: a to sploh kdo bere? :lol:
Prispevki: 1130
Odgovor Avtor: Unikat » 12. Oktober 2008, 21:38
Ja, jest že. Sam mi je škoda vmes smetit s komentarji, ko pa lepo pregledno evidenco vodš :-) No, ni mi jasn zakaj avto nastavljajo zdej med dirko na pa pred dirko na kakšnih testih, niti ga ne znajo vedno pravilno nastavt zato verjetno tud rezultati niso najboljši.
Odgovor Avtor: gorazd0 » 12. Oktober 2008, 21:48
berem :D
Odgovor Avtor: Thomas22 » 12. Oktober 2008, 22:06
Beremo, beremo !
Prispevki: 5489
Odgovor Avtor: BackW00d » 12. Oktober 2008, 22:46
normalno da berem :D
Prispevki: 5058
Odgovor Avtor: karel » 13. Oktober 2008, 06:47
Itak da beremo,če pa bi bili rezultati boljši bi pa
verjetno tudi vpili ;-)
Odgovor Avtor: irCAR81 » 13. Oktober 2008, 07:25
Beremo! Ne odnehaj!
CrazyDriver
Prispevki: 288
Kraj: Rovte
Odgovor Avtor: CrazyDriver » 13. Oktober 2008, 18:26
Ja sej ne mislem nehat :D Sam preverjam :oops:
Kar se pa rallya tiče, oba sta zdaj zanesljivo med točkami vedno, kar je za razliko od leta, dveh let nazaj napredek :lol: Upam pa da bo kmalu nova Impreza tudi kako zmago pripeljala :-P
Latimeria
Prispevki: 121
Kraj: koper
Odgovor Avtor: Latimeria » 14. Oktober 2008, 20:19
Samo, če pogledamo je to 5. mesto praw rezervirano za solberga na skoraj vsaki dirki :? že 3 leta je tko...
