Subaru boxer diesel
Novo pri Subaruju
gore
Prispevki: 955
Subaru boxer diesel
Odgovor Avtor: gore » 30. September 2006, 07:06
Tole je japonček izjavil v Parizu ... :D
"As announced at the Geneva Motor Show last year, we are enhancing our Subaru boxer engine lineup, and I’m pleased to announce that the development of the world’s first horizontally opposed diesel engine, the Subaru Boxer Turbo Diesel is nearly complete.
The superb rotational balance of the horizontally-opposed engine allows low vibration because the pistons counteract each other to cancel it out. Moreover, with its firmly supported crankshaft, the crankcase construction is strong enough to resist huge combustion pressure. The horizontally-opposed engine’s character is proving an excellent match for a diesel engine.
Also, the adoption of a thin journal for the crankshaft and turbo charger placed under the cylinder block enhances all the advantages of the Boxer Engine, which are “Low center of gravity” ”Low vibration” ”High rigidity & compactness” This delivers diesel’s powerful torque from the engine to the wheels, and increases traction, making the Subaru Boxer Turbo Diesel yet another achievement of Subaru’s advanced technology.
Last but not least, the Subaru Boxer Turbo Diesel boasts lower CO2 emissions in consideration of the environment.
I anticipate unveiling the Subaru Boxer Turbo Diesel engine next year at Geneva Motor Show."
:D
galimim
Prispevki: 555
Odgovor Avtor: galimim » 30. September 2006, 08:17
važn da bo delu tok dobr kokr bencinski
Subaru XV 1.6 2021
Odgovor Avtor: niva13 » 30. September 2006, 10:29
Subaru’s new turbodiesel engine would be modular, and will be introduced as a 2.2 liter 4 cylinder boxer, as well as a 3.3 liter 6 cylinder boxer. Since it is modular, technically a 4.4 liter 8 cylinder boxer could also be possible.
Subaru expects half of total Subaru sales in Europe to be diesel-powered by 2010.
galimim
Prispevki: 555
Odgovor Avtor: galimim » 30. September 2006, 10:46
8 cilinderski boxer WOW :-f :-f :-f :-f :-f
Subaru XV 1.6 2021
Odgovor Avtor: niva13 » 30. September 2006, 10:52
Uh pa kaksen sound bo to proizvajal :-P
ok vem, da to ni pomembno, pac ne morem iz svoje koze
subidu
Odgovor Avtor: subidu » 30. September 2006, 10:55
Kaj ni pomembno, sevede je! Če ne bi bilo si ne bi že vsak ta drug dal druzga auspuha gor ... :-)
Odgovor Avtor: Sajmon » 30. September 2006, 11:12
Končno! Čeprav... še za vsakim, tudi tako dobrim dizlom, se kadi in svinjsko smrdi. In še pri nobenem dizlu nisem slišal dobrega zvoka, razen pri kakšnem M.A.N.-u :-P
Ampak H8 dizel, to bo pa navora za asfalt ven metat :shock:
kljub vsemu... na koncu vem, da bom enga imel, če ne bo prej kaj bolj vodnatega na tržišču
Odgovor Avtor: niva13 » 30. September 2006, 11:27
saj kamijonski zvok sem mislila, ceprav tud unih 8 cilindrov.....glavno, da lepo zabasira :-P
pa se ekolosko osvescen bos in gorivo kar doma naredil :-P
http://en.wikipedia.org/wiki/Biodiesel
Odgovor Avtor: TORA! TORA! TORA! » 30. September 2006, 12:01
Sajmon napisal/-a:Končno! Čeprav... še za vsakim, tudi tako dobrim dizlom, se kadi in svinjsko smrdi. In še pri nobenem dizlu nisem slišal dobrega zvoka, razen pri kakšnem M.A.N.-u :-P
dej pejt iz svojhe vasi malo ven da namesto golf enk čuješ še kakšne BMW šestake in podobno, ki ne smrdijo in ne kadijo....JA!
a je Joiči Motoju kamen na glavo padu al kaj....he he, kaj naj rečem
KONČNO!!! :lol:
Odgovor Avtor: Freak » 30. September 2006, 16:54
Dizli smrdijo :-P :twisted:
Sam H8,kak zvok bo to delal??? :shock: Se bencinarja nej nardijo H8,pa je cista zmaga :cool:
Odgovor Avtor: TORA! TORA! TORA! » 30. September 2006, 18:02
Freak napisal/-a:Dizli smrdijo :-P :twisted:
bencinar je za pičke k so fancy....dizl pa za robate dece in babe :lol:
gore
Prispevki: 955
Odgovor Avtor: gore » 30. September 2006, 18:48
TORA! TORA! TORA! napisal/-a: bencinar je za pičke k so fancy....dizl pa za robate dece in babe :lol:
To je stavek :D
Ko obrneš ključ, se mora avto stresti ...
Odgovor Avtor: gorazd0 » 30. September 2006, 19:26
Roke smrdijo po nafti... pozim so problemi... vse to za 1 liter nižjo porabo?
Je pa res - kak sajevček šestak (tudi petak) ima prav lep zvok. :D
gore
Prispevki: 955
Odgovor Avtor: gore » 30. September 2006, 19:49
gorazd napisal/-a:Roke smrdijo po nafti... pozim so problemi... vse to za 1 liter nižjo porabo?
He, he. Kot si prebral prejle - za pravega možaka je dizel ... :D
Roke smrdijo po nafti, če tankaš tam, kjer traktorji in tovornjaki. Sicer ne.
Pozimi so težave le pri uporabi Petrol in OMV dizlov (no, pa še to je sedaj menda preteklost). Edino malo kasneje se segreje v kabini, to je pa res.
No, poraba je običajno pri primerljivih več litrov manjša - 2-3 litre (primerjam Legi/Fori proti Golf/Passat 4motion - kar je povsem primerljivo), kar preko leta nanese - meni med 400 in 500 tisočaki razlike!!! Če predvidevam, da bom kmalu imel Forija dve leti in da je samo razlike pri gorivu potem skoraj milijon ... se pa človek zamisli. Sedajle bi mi miljonček prav lepo sedel v žep :D
Koliko je to v petih, desetih letih?
Največji čar dizla pa je navor - ko nežno dodaš gas, začutiš pa moč.
Vprašaj Yetija, ki je navajen Subija (ki je sicer še celo poznan po navoru), ko je prvič v službi dobil dizla in šel prehitevat v klanec. :shock:
In ko skoraj stojiš, pa dodaš gas v drugi, avto pa kot da ni nič.
Ali pa ko poslušaš predenje motorja v križišču. Uf, in ko bo Subarujev brbotavček spuščal takšne glasove, bo to zakon. No, vsaj zame. Ljudje smo pač različni. In prav je tako.
Zanimiv je tudi hibrid - poleti sem nekaj dni temeljito prevozil Toyoto Prius. Za tako veliko avto je poraba med štirimi in petimi litri res ugodna. In to ob klimi, prevozu tovora na Veliko planino ...
Odgovor Avtor: TORA! TORA! TORA! » 30. September 2006, 19:50
roke smrdijo?...sej maš rokavičke
pozimi problemi....mogoče z japonci in francozi (nekateri nimajo ogrevanega naftnega filtra...in se zapaca zparafinom).....kar se pa tiče samega užiganja, pa sploh ni panike (niso več golfi I)
1l manša poraba?....pomoje da kr več, signum 3.0V6 CDTI 180PS...porab 8l/100...bencinar 2.6 V6 z 170ps..pa 11l/100 (pa gre dizl neprimerno bolš)
bmw 530d 204PS....7,5l/100.....528 (194PS)..pa 10l/100....in prot dilzu ne gre nikamor!!!
zdej mi pa ti povej če se motim?
PS...zgornje vrednosti so realne(porabe)
pa še za info..moj signumčk 2.2 DTI (automatic) ma mestno porabo 6,5l/*100, izven pa 5,8.....zdej mi pa ti prpel zraven bencinski avto k bo tolk šel in 1l več pil?
