2007 Subaru impreza STi
Zagor
Prispevki: 33
Pridružen: 14. April 2015, 04:00
Kraj: Karlovac
Odgovor Avtor: Zagor » 14. April 2015, 17:52
Auto od dobrog prijatelja:
http://img12.imageshack.us/img12/7358/s33wallpaper.jpg
http://img193.imageshack.us/img193/4854 ... 981130.jpg
http://img594.imageshack.us/img594/1610/dsc2864.jpg
http://img687.imageshack.us/img687/6369/dsc2891m.jpg
http://img269.imageshack.us/img269/3808/dsc2935.jpg
http://i1305.photobucket.com/albums/s55 ... 294690.jpghttp://i1305.photobucket.com/albums/s55 ... 68bb57.jpg
http://img412.imageshack.us/img412/1700/dsc0038h.jpg
http://i1305.photobucket.com/albums/s55 ... ef77e1.jpg
http://i1305.photobucket.com/albums/s55 ... 28aa0e.jpg
Few modifications:
http://a.imageshack.us/img833/3231/img0095k.jpg
http://img202.imageshack.us/img202/2133/dsc0059z.jpg
http://img688.imageshack.us/img688/4639/dsc0025am.jpg
https://lh3.googleusercontent.com/-c-rT ... C_1121.JPG
https://lh4.googleusercontent.com/-y-JM ... C_1124.JPG
https://lh3.googleusercontent.com/-_rMG ... C_1125.JPG
https://lh6.googleusercontent.com/-gz99 ... C_1126.JPG
https://lh3.googleusercontent.com/-Fw4g ... C_1129.JPG
https://lh5.googleusercontent.com/-i-43 ... C_1131.JPG
https://lh4.googleusercontent.com/-7D-y ... C_7577.JPG
https://lh3.googleusercontent.com/-3Kiw ... C_7595.JPG
http://img8.imageshack.us/img8/7427/dsc3407l.jpg
And now things started to get serious:
Whiteline rear anti roll bar 3 point adjustable 22mm
http://i43.photobucket.com/albums/e380/ ... C00055.jpg
http://i43.photobucket.com/albums/e380/ ... C00057.jpg
http://i43.photobucket.com/albums/e380/ ... C00056.jpg
Whiteline front anti roll bar 2 point adjustable 22mm
http://i43.photobucket.com/albums/e380/ ... C00060.jpg
Whiteline Anti lift kit
http://i43.photobucket.com/albums/e380/ ... KCA362.jpg
Pistons & rods
https://fbcdn-sphotos-b-a.akamaihd.net/ ... 4106_n.jpg
http://i1305.photobucket.com/albums/s55 ... 9e47d1.jpg
Ceramic coating
https://fbcdn-sphotos-d-a.akamaihd.net/ ... 1501_n.jpg
EFR 6758
http://i1305.photobucket.com/albums/s55 ... 2833ed.jpg
http://i1305.photobucket.com/albums/s55 ... 1366298256
http://i1305.photobucket.com/albums/s55 ... 1366298274
http://i1305.photobucket.com/albums/s55 ... 1366298290
Cylinder head porting
http://i1305.photobucket.com/albums/s55 ... 2f9b2f.jpg
http://i1305.photobucket.com/albums/s55 ... 11ed7e.jpg
http://i1305.photobucket.com/albums/s55 ... 0da1bb.jpg
http://i1305.photobucket.com/albums/s55 ... b8dba3.jpg
http://i1305.photobucket.com/albums/s55 ... dc60cd.jpg
http://i1305.photobucket.com/albums/s55 ... f14706.jpg
http://i1305.photobucket.com/albums/s55 ... e7fdd0.jpg
http://i1305.photobucket.com/albums/s55 ... 01203f.jpg
http://i1305.photobucket.com/albums/s55 ... d57092.jpg
http://i1305.photobucket.com/albums/s55 ... ea04c7.jpg
http://i1305.photobucket.com/albums/s55 ... a2b478.jpg
http://i1305.photobucket.com/albums/s55 ... 8f64d4.jpg
Copper "O" rings on the engine block
http://i1305.photobucket.com/albums/s55 ... fcbe7a.jpg
Almost finished, they are waiting for Supertech valves :)
https://fbcdn-sphotos-c-a.akamaihd.net/ ... 1694_n.jpg
Vipec Plug&Play ECU
ARP 625 bolts
ARP block studs 2000
ACL race bearings
Subaru OEM gasket kit
Supertech +1mm valves
Cylinder head porting (also cylinder head and exhaust manifold will be ceramic coated)
Engine block work, with copper "O" rings on the block
BorgWarner EFR 6758
FMIC
Kelford 264/260 camshafts
Kelford valve springs
Wiseco pistons (ceramic coated)
CP Carrillo H-beam connecting rods
Fluidampr
Oil cooler
12mm oil pump
3" custom made exhaust by Milletech (don't mix it with Milltek) :)
Helix twin plate organic clutch with Helix flywheel
Zagor
Prispevki: 33
Kraj: Karlovac
Re: 2007 Subaru impreza STi
Odgovor Avtor: Zagor » 14. April 2015, 17:55
Auto je vjerojatno na prodaju za cca. 27.000 EUR (nije nigdje u oglasnicima, jer se ne moze odluciti da li bi je prodavao ili ne), jer je kupio ovo:
https://scontent-vie.xx.fbcdn.net/hphot ... 1133_o.jpg
Prispevki: 8780
Odgovor Avtor: nebivedu » 14. April 2015, 21:34
Pogled na krčki most iz Jadranova. :twisted:
Zagor
Prispevki: 33
Kraj: Karlovac
Odgovor Avtor: Zagor » 14. April 2015, 23:30
nebivedu napisal/-a:Pogled na krčki most iz Jadranova. :twisted:
Nije :)
Pogled je sa otoka Krka, iz Voza (tamo gdje su prije trajekti pristajali)
http://www.pohrani.com/f/2U/12U/18ob6hBc/001.jpg
urbancebulj
Prispevki: 2237
Odgovor Avtor: urbancebulj » 15. April 2015, 05:44
Kul specifikacije.
:.sup
Prispevki: 8780
Odgovor Avtor: nebivedu » 15. April 2015, 07:34
Zagor napisal/-a:
Nije :)
I to poznajemo. Imam vikendicu u Čižićima pa smo subarujem "obradili" cijeli Krk i skoro sve plaže, osim malu i vela luku nisam još uspio subarujem. Ali sam vidio land rovera kod kafiča u vela luki, tako da taj izazov još ostaje.
pero_mt
Prispevki: 62
Pridružen: 20. Januar 2013, 18:05
Odgovor Avtor: pero_mt » 15. April 2015, 07:35
Konkretna :) :cool:
GT3 je pa tudi vrhunska izbira! :)
impreza911
Prispevki: 1369
Kraj: Gornja Radgona
Odgovor Avtor: impreza911 » 15. April 2015, 08:48
odlično :c
Subaru Impreza RS
subi4x4
Prispevki: 759
Kraj: Podljubelj
Odgovor Avtor: subi4x4 » 15. April 2015, 09:59
zelo lepo, khm...ne vem še :D,
kdo je sestavljal avto in delal mapo?
In USA you drive car.
In Japan car BREAK you.
Zagor
Prispevki: 33
Kraj: Karlovac
Odgovor Avtor: Zagor » 15. April 2015, 15:20
Ja sam u Omislju preko ljeta, tamo imamo kucu :) Svijet je malen :lol:
subi4x4 napisal/-a:zelo lepo, khm...ne vem še :D,
Hic - THPerformance
subi4x4
Prispevki: 759
Kraj: Podljubelj
Odgovor Avtor: subi4x4 » 16. April 2015, 20:34
Hic je delal mapo tudi na moji stijki, vsa čast :c , mogoče veš, če ima še celico turbo?, mislim da je on imel eno "navito" ?
Zagor
Prispevki: 33
Kraj: Karlovac
Odgovor Avtor: Zagor » 17. April 2015, 00:12
subi4x4 napisal/-a:Hic je delal mapo tudi na moji stijki, vsa čast :c , mogoče veš, če ima še celico turbo?, mislim da je on imel eno "navito" ?
Mislim da ju jos uvijek ima...
