Izpušni sistemi
Odgovor Avtor: Thomas22 » 18. November 2008, 22:51
Resonators, also known as Helmholtz resonators are sections of exhaust pipe that expand to a larger diameter and allow the sound waves to reflect off the walls and cancel out. Resonators are mostly used to reduce raspiness and popping. Resonators are similar to an Expansion chamber, only for 4 stroke engines. They do not produce much back pressure.
Many North-American cars (and possibly cars in other parts of the world) made since the early to mid 1990's can have up to 3 distinct (but similar looking) exhaust components downstream from the catalytic converter(s). Each of these components may be called resonators or mufflers. Usually only the last component is the actual muffler, and the other components are the resonators.
Odgovor Avtor: Thomas22 » 18. November 2008, 23:06
Ali je tole že kdo kdaj uporabljal?
http://www.tanabe-usa.com/images/Exhausts/buffle2.jpg
Odgovor Avtor: Thomas22 » 18. November 2008, 23:10
Al pa tole
http://redhat3.admarkonline.com/~nippon ... -large.jpg
Ni mi povsem jasno kako lahko s tem zmanjšaš zvok. Če zmanjšaš premer, naj bi se zmanjšal zvok :? ?
Odgovor Avtor: danci1973 » 18. November 2008, 23:21
Meni se pa zdi čisto 'logično', da manjša odprtina pomeni manj hrupa.
In na mopedu imam nekaj temu podobnega in deluje.
Odgovor Avtor: gorazd0 » 19. November 2008, 00:44
BojcLO je mel nekaj podobnega na starem belem limo legacy turbo; razlika je bla očitna;
pač - plini se zaletijo v zadnjo steno lonca.. in iščejo pot ven - v tem primeru 20cm nazaj.. in potem ven;
Odgovor Avtor: bojc T » 19. November 2008, 07:52
Ja itak je k noč pa dan,
je pa tut avto čist drgač vleku
Odgovor Avtor: Thomas22 » 19. November 2008, 09:24
Bojc, a si imel takšnega kot je na drugi sliki od Nippona, da je šla cevka v tisto, ki pride iz izpuha?
Jaz imam skozi zadnji locen cev fi 46 (premer na izhodu, ker je nekolijko v konus zaradi navora), naprej pa imam fi 100 nastavek. Zato mi ni jasno, če dam tak nastavek not, da bi s tem zmanjšal zvok.
Ma najboljš, da probam.
Odgovor Avtor: Thomas22 » 21. November 2008, 21:00
Rad bi naredil športni izpušni sistem tih. Zato sem mislil narediti več teh resonatorjev pred zadnjim loncem.
Odgovor Avtor: Thomas22 » 15. December 2008, 23:25
Odgovor Avtor: Thomas22 » 12. Marec 2009, 20:58
Uspešno sem naredil distančnik za zmanjšanje zvoka. Razlika pri zvoku je očitna.
Glede moči pa se mi zdi da jo je v spodnjih vrtljajih več, v zgornjih pa zmanjka.
Danes sem tudi nabavil material za izdelavo kolektorja. V bližnji prihodnosti naredim takega kot ga je pripopal Cheno.
Odgovor Avtor: Psssiho » 12. Marec 2009, 21:36
Boš poslikal in pokazal ;-)
Odgovor Avtor: Thomas22 » 16. Marec 2009, 20:30
Začel sem z izdelavo izpuha, lepo počasi, se mi nikamor ne mudi.
Zaenkrat upam, da bo toliko materiala (3m cevi fi 45, 2m cevi fi 40 in nekaj 90 stopinskih kolen) zadosti za kolektor:
http://www.subaru-slo.net/userpix/110_L ... rial_1.jpg
Prirobnice za na motor sem naredi že pred časom. Danes sem se pa lotil izdelave "hlačk" (prehod iz dveh cevi v eno) po moje najtežje zadeve.
http://www.subaru-slo.net/userpix/110_L ... uh_1_1.jpg
Odgovor Avtor: gorazd0 » 16. Marec 2009, 22:42
Ti prinesem "borlo" za mušter... če mi boš pomagal pri mojem izpuhu; vidim da imaš spretne roke :D
Odgovor Avtor: birdy » 17. Marec 2009, 00:17
ce te tomas ne bo izkoristu, bi te pa jest, da premerim vse dolzine cevi premere itd.... :)
ce mi slucajno ne uspe prvlect moje lastne borle iz amerike :)
Odgovor Avtor: gorazd0 » 17. Marec 2009, 00:38
če misliš daj čimprej,.. ker dolar raste... :?
